Fenders
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Fenders
i know i should be posting this is the wanted section,but does anyone have convertible front fenders for a camaro. i dont want to cut up some coupe fenders and modify them to fit my car. thanks,bryan
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
i thought convertibles were originally t top cars so shouldn't the fenders be the same on all of our cars?
Car: 1992 Jade Green---Trans Am Converti
Do a search, they are originaly the same fenders but are modified to fit the ASC frame rails.
Kevin D.
Kevin D.
Car: 91 RS Convertible
Engine: 305 TBI
Coupe fenders fit just fine.
The only difference is the mounting bracket.
My 91 has a coupe fender on it and the only thing changed was the mounting bracket near the door.
It's the only thing that changed to my knowledge.
Due to the added support to the frame.
As long as you have the bracket to your original fender... they only have to weld that part to the coupe fender for a fit.
Depending on the dameage of course....
You also have to cut off the coupe mounting bracket as well, which is basically the lower part of the fender. It's not as simple as welding the bracket on.
Kevin D.
Kevin D.
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
i changed mine. had to cut off about 5" from the bottom of the fenders and reuse the brackets from my old fenders, pain in the *** but worked just fine.
i have 2 new fenders for sale. not gm tho. 100 for both
morrow
Jan 13, 2024 12:29 PM
