rear trunk plastic?
Old Jun 9, 2006 | 01:55 AM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
rear trunk plastic?
does anybody have any pics of their trunk plastic. my car didnt come with it when i bought it..lol but i have some panels if i need to convert them just need to see what others look like
Old Jun 9, 2006 | 07:42 AM
chuck88iroc's Avatar
Car: 1988 IROC-Z Convertible
Engine: 305 LB9
Transmission: MK6 5-speed
Axle/Gears: G80, G92, GM3
Here are some from my 1988 IROC. Hope they might help. If you need some thing specific I can get a picture of it.
Chuck
Attached Thumbnails rear trunk plastic?-trunk_area.jpg   rear trunk plastic?-trunk_lt_side.jpg   rear trunk plastic?-trunk_rt_side.jpg
Old Jun 9, 2006 | 02:47 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Chuck
Clean car, Chuck!
Old Jun 11, 2006 | 12:05 AM
GMZombie's Avatar
thanks chuck that is just what i needed to see. now i can mod the extra stuff i got the other day to fit in...and yes that is a clean and RED car lol cool stuff. oh how about where the trunk shocks are...is there anything cut over on that plastic....can i get an upclose shot of that and maybe of that peice out of the vehicle so i can see how they cut it...thanx
Old Jun 11, 2006 | 04:47 PM
Engine: 305 LB9
Attached are some pictures of the side panels showing the cutouts for the trunk hinges and supports. Sorry, but I didn't get any with them out of the trunk. Hopefully these will help you out though.
Thanks guys for the comments on the car!
Chuck
Left side pictures attached here. Right side will be in second post.
Attached Thumbnails rear trunk plastic?-lt_side_1.jpg   rear trunk plastic?-lt_side_2.jpg   rear trunk plastic?-lt_side_3.jpg
Old Jun 11, 2006 | 04:50 PM
Engine: 305 LB9
Here are the photos of the right side panel.
Chuck
Attached Thumbnails rear trunk plastic?-rt_side_1.jpg   rear trunk plastic?-rt_side_2.jpg
Old Jun 11, 2006 | 05:05 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
Thanks Chuck,
I bought a used set of panels since my '92 came with molded
carpet panels. The drivers side doesn't want to fit very well.
The forward portion of the lid wants to stay open.
Does the lock seem to help? I took the latch portion out
since my panel didn't come with a key.
Thanks again.
Old Jun 12, 2006 | 06:40 AM
Engine: 305 LB9
That door on the stowage compartment is pretty cheesy, as I am sure you have found. Mine fits OK and I am sure the latch helps but it is not exactly square in the openning. I would think you could find a similar latch/lock that would work.
Chuck
Old Jul 2, 2006 | 04:00 PM
IrocZ85's Avatar
Panels
Well I have clean set of black trunk panels and black carpet from a 89 Vert Looking for a decent offer.
Old Jul 3, 2006 | 12:17 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Originally Posted by Cadillac
Clean car, Chuck!
agreed.
Old Jul 3, 2006 | 07:18 PM
Engine: 305 LB9
Thanks for the complements!!
Chuck
Old Jul 4, 2006 | 08:05 AM
plndtx's Avatar
What do the electrical contacts power?
I don't have them on my '92.
Could they power an amp that is mounted on the underside of the deck lid?
Old Jul 4, 2006 | 01:51 PM
Engine: 305 LB9
The contacts are for the center brake lights on the spoiler.
Chuck
Old Jul 6, 2006 | 08:32 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I just bought a Conert, where can I get this piece, is it a standard extrusion or is it a specialty piece?
What I am talking about is the Black piece that attaches to the cut edge of the interior panel.
Old Jul 6, 2006 | 08:39 AM
okfoz's Avatar
Actually the contacts were originally used for the rear window wiper that was an option thru 1986. When the center brake light was re-located to under the spoiler on the Firebirds and in the spoiler on the Camaros in 1987 they used the same contacts for that. When they went back to the third brake light on top of the rear window in 1991 the contacts were no longer needed, it also lowered production costs slightly. I believe one of the things that may have contributed to the 87-90 design was the introduction of the convertibles in 1987.
John
Old Jul 6, 2006 | 10:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its just standard cheapie trim crap.
John
random trivia:
in the early 87 model year ASC verts, the rear 3rd brake light was a FORD truck unit.. later, in 87 (the year) the DOT approved chevys spoiler 3rd brake light lense, and all verts started using it... and it magiclly appeared on the coupes from then on to..
also, whoever picked the bulbs for that lense should be shot.. total PITA to find.. and replacements get too hot.... i ended up modding mine to be LED based. heh.
Old Jul 6, 2006 | 12:32 PM
okfoz's Avatar
Originally Posted by MrDude_1
random trivia:
They actually sanded off the Ford Emblem IIRC...
Did the Firebird and Camaro use the same Lens from 87-89? What I do not understand is why ASC did not use the stock Lens assy for the Firebirds, they used a cut wing from the Firbirds, why not use the lens assy too...
Old Jul 6, 2006 | 01:17 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The 91-92s got the camaro brake light and ducktail-esque spoiler. The DOT code on my brake light even says 87.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
MORREALE5
Sep 13, 2015 09:16 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
