Convertable top frame spring wires
Old Sep 26, 2006 | 07:00 PM
axlenut's Avatar
When I put the top down on my '89 one of the spring wires on one side broke. They are both bent real far like they maybe should not? These are the wires that are above the side windows and are nearly straight when the top is up. I went to put the top down on my '91 and the hatch would not close. The spring wires looked real bent with the paint flaking off .....
Am I doing something wrong? Is there 2 ways to fold these things down?
thanks!
Old Sep 26, 2006 | 11:36 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
That rod is what I call the "flip rod". I'm out of stock on them. Until you can get a replacement you can remove them from both sides. From now on you'll have to manually raise the #2 bow as you lower the top. If you don't raise the bow the top will fold up short and hit the top of the rear seats.
Lon Salgren
Top-Down Solutions
Old Sep 27, 2006 | 08:28 PM
axlenut's Avatar
yikes
The 91 has the springs there like the '89 used to. Am I having the #2 bow go the wrong way and bending the springs till they break plus the top won't go all the way down? I must be because the hatch won't close when I get my tops down. I have a few of these cars but almost never put the tops down. Watch out, keep me away from any convertibles if you want your top down.:
Old Oct 2, 2006 | 08:50 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Just unbolt the flip rods and leave them off. Mine are in the garbage. When you want to take your top down: From the driver's side, lift the front with your right hand and push the #2 bow toward the rear as you retract the top. This will fold it neatly and effortlessly behind the rear seat.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
