My '91 TA Ragtop RPO Codes
I just ran my rpo codes through the rpo decoder. Pretty cool! My car is now a 5-speed. Are there any visible codes on the engine to see if the engine is still original? Also the original seats are gone. Does anyone have pics of what the original seats looked like? Which other cars/years used the same seats?
Looking for a set of correct seats and I am also looking for the correct stereo for this car. Does anyone reproduce the rear speaker covers? Mine are shot!
Here are the codes! (I couldn't read them all)
AAA - 4-WAY MANUAL SEAT ADJUSTER
AJ3 - RESTRAIN SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AQ9 - SEAT, FRT PASS A DRIV, RECL
AU3 - LOCK CONTROL, SIDE DR, ELEC
A31 - WINDOW, POWER OPERATED, SIDE
BC8 - ORNAMENTATION, INTR, DR MAP POCKETS
B84 - ORNAMENTATION, EXTR MLDG, BODY SIDE
C60 - HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG7 - MIRROR 0/S, LH RH REM CONT, ELEC, PAINTED
D8N - SENSOR, VEH SPD
E5Z - SPEEDOMETER ADAPTOR (DELETE)
GU2 - AXLE REAR, 2.73 RATIO
IL2 - TRIM - INTERIOR DESIGN
J41 - BRAKE SYSTEM, PWR FRT DISC, RR DRUM, CAST IRON
K34 - CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K60 - GENERATOR 100AMP
LB9 - ENGINE, GAS, 8CYL, 5.0L, TPI, HO
MD8 - TRANSMISSION, AUTO, 4SPD, THM 700R4
MXO - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
PW7 - WHEEL, 16X8, ALUMINUM, DIAMOND SPOKE
T93 - TAIL STOP LAMP, SMOKED
T96 - LAMP, FOG
U83 - ANTENNA, POWER, CITIZENS BAND/RADIO TRIBAND
UX1 - RADIO, AM/FM STEREO CASSETTE EQUALIZER
U62 - SPEAKER SYSTEM, DUAL COAXIAL
U75 - ANTENNA, POWER, RADIO
VAN - ASSEMBLY PLANT, VAN NUYS, CA
VK3 - LICENSE PLATE, FRT MOUNTING PKG
NA5 - EMISSION SYSTEM, FEDERAL, TIER 0
NP7 - STEERING COLUMN, EEC APPROVED
WS6 - PERFORMANCE PACKAGE, SPECIAL
1SC - PACKAGE, OPTION 03
1SZ - ???
45Q - MOULDING COLOR, MED GREEN MET (91)
45U - PRIMARY COLOR, EXTERIOR, MED GREEN MET (91)
52P - WHEEL COLOR, GOLD MET (91)
6ZX - SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
62T - TOP COLOR, LT BEECHWOOD MET (91)
66I - INTERIOR TRIM, MED BEECHWOOD (91)
662 - TRIM COMBINATION, LEATHER, MED BEECHWOOD (91)
669 - SEAT BELT COLOR, MED BEECHWOOD (91)
8NM - SPRING, COMPUTER SELECTED, REAR, LEFT HAND
9NM - SPRING, COMPUTER SELECTED, REAR, RIGH HAND
WS4 - MODEL CONVERSION, TRANS AM
T96 - LAMP, FOG
1SZ - ???
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
what do you mean inside the center console... I guess I'm looking in the wrong spots.... or I don't know what the center console is.... I think I looked there before and it wasn't there....
