question about the rear spoiler
Old May 7, 2007 | 09:27 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
ok now i need to get my car prepped and ready to paint it and im wondering how in the hell do i remove the wing? how is it holding onto the trunk?
Old May 7, 2007 | 10:06 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Re: question about the rear spoiler
When you open the trunk Look up at the top of the lid & you will see like 4 or 5 black rubber stoppers. Just pry them off & the bolts are there.
Old May 7, 2007 | 11:59 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
90-92 also has a single screw on each outer end of the spoiler. That screw mounts to a L-shaped bracket that slips beneath a bracket that is pop-riveted to the trunk lid.
Lon
Old May 8, 2007 | 10:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
LOL, my "screws" were pop rivets.
I had 4 bolts on the under side of the deck.
2 pop rivets in each end.
Then the back was stuck down with 3 strips of double sided tape.
Old May 9, 2007 | 12:00 AM
GMZombie's Avatar
i actually dont have bolts there...i did find what was holding it on...looks like someone put screws in the small side of the front of the spoiler and then in the bottom rear? they were filled and whatnot but i just so happen to see one that wasent very good. anybody else come this way?
Old May 9, 2007 | 12:13 AM
lonsal's Avatar
What you should find are gray molded plastic bases that are glued to the spoiler with what looks like hot-melt glue. Molded into the plastic bases are a threaded metal stud. As I recall there were nuts with shouldered washers that thread onto the studs. The problem is with age the plastic cracks and the studs come free of it, so nothing is attaching the spoiler. What you're finding is a prior owners attempt to repair them.
Lon
Old May 9, 2007 | 09:28 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Lon
Have you considering marketing a spoiler repair kit? I've been eyeing my spoiler since I pulled it for paint. All the mounts are no longer attached. I guess the best way to reinstall them would be fiberglass or body panel adhesive..... Just haven't had the initiative to mess with it.
-jason
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
