tonneau switch not working
Old May 17, 2007 | 08:29 PM
89irocrochester's Avatar
Car: 1989 Iroc Convertible
I am having difficulty trouble shooting my tonneau release switch not working on my 89 iroc convertible. The hatch pull down unit is new so I don't believe that is the problem. How do I find out if the relay is bad or if the solenoids are bad? Is it possible to just run new hot wires from the release switch to each solenoid onits own fuse or is there a better way to resolve my problem.
Old May 17, 2007 | 09:03 PM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
Re: tonneau switch not working
pull the switch and ground the tan wire. if they pop, then its not the relay.. it'd be the switch i think. if it doesnt, double check your trunk button under the pull down unit. I just checked mine and it was the trunk button that was broke. I jumped it and now i have no issues.
Old May 25, 2007 | 11:13 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
I had this problem. When I finally tracked it down I found that the circuit was not plugged into the trunk release... There should be a place to plug this into your release. If not - you can find the plug and just jump across the two contacts and it should work...
Good Luck!
Speedy
Old Jun 7, 2007 | 08:27 PM
drshirk's Avatar
Car: 91 Camaro RS Convertible
Where is the trunk button? I am not sure what you mean by the pull down unit.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 9, 2015 01:15 PM
