convertible top troubles
Old Aug 25, 2007 | 05:59 PM
Fastcamaro87's Avatar
Ok, so the top on my 88 iroc came unglued at the bottom rear section. so i reglued it to the frame, and now i cant get it to close. when the front is latched the rear wont latch, and vice versa. Is there anything to adjust? this is driving me crazy. any help will be greatly appreciated.
Matt
Old Aug 25, 2007 | 08:42 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: convertible top troubles
more than likely you stretched it too much when you glued it.
Old Aug 28, 2007 | 10:45 PM
Ok, so i pulled the top off bow#5 (or atleast i think it is.. its the rear most part of the top.) thinking maybe i had stretched it to much when i reglued it. from what i can tell it looks like the fabric of the top has shrunk, is this a possibility?
With the top up and latched, there is atleast 1-2 inches the fabric would need to stretch, to reach the area (bow#5) it gets glued to.
This car was like this when i bought it. So i dont have any way of knowing how it came unglued etc.
Old Aug 28, 2007 | 11:05 PM
jstoltz's Avatar
is it an old top or new (newer) when you put a new top on it shrinks. it is a fabric so just think of it as a new shirt then you wash it. just work it around the best you can. best of luck to you sorry I can't be of more help but it is something where unless I was there I can't do much.
Old Aug 29, 2007 | 08:47 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you glued it too tight, all you can do is try to stretch it.... latch the front, and try to close the back.
Old Aug 29, 2007 | 04:55 PM
91 Ragtop's Avatar
Car: 1991 Trans Am Convertible
Transmission: 5-Speed
The top that is on mine is definately a tight fit. I usually have to slam the back down to get it to latch. This is after I have latched the top. If I do tha back first, the front isn't going to latch at all.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
