pictures needed of space between tonneau
Old Oct 6, 2007 | 09:36 PM
rlapenna's Avatar
Car: 1988 Iroc Z Convertible
Engine: 5.0 TPI LB9
Transmission: 5 Speed
Axle/Gears: 3.08
and trunk. i bought this car in june so i dont know all the history, i dont think it was ever in an accident as best i can tell. i have looked everywhere. but the tonneau cover does not close right, sometimes the weather stripping gets stuck between the trunk and tonneau but more importanty, the left side (drivers) doesnt sit flush, its like its warped or maybe someone opened the trunk with it open. it just doesnt sit right. if i put pressure on it pressing down it does go down further, its like its sprung or something. also, if someone could take a picture of the gap between the sail panel and tonneatu that would be great. i dont know what the deal is. I will take some pics too.
car: 88 iroc vert.
Rob
Old Oct 7, 2007 | 10:35 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: pictures needed of space between tonneau
So I understand you perfectly, could you post pics of what exactly what you want to see (angle and location) and I will then take the exact same pics of mine for you.
Old Oct 8, 2007 | 02:12 PM
rlapenna's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 3.08
i think i have found the issue, i just gave the tonneau a slight pushe when it was open and it seems to have needed a little bend. on the inside however, where the tonneau meets the sail panel....that big gap seems to be, being caused by some disguuising someone did. the mount that that the rear seat back pin mounts to, is rotten where it meats the frame, on that same mount is where the sail panel screws to. looks like someone drilled new holes in that bracket. i guess i will need to have it cleaned up and welded.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
