Need Pic
Old Apr 7, 2008 | 05:54 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Need Pic
when sitting in the seat, on your outside above the shoulder is some coathanger thin rods.
Can someone get me a side pic of that. Is it to be strait, have a slight bend in the middle?
Can supply email via pm for hi-res version.
Old Apr 7, 2008 | 04:03 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Re: Need Pic
the flip rods, thay are bent looking. ill see if i have a pic on hand
Old Apr 7, 2008 | 08:42 PM
Dale's Avatar
Engine: 350 S-TPI
Re: Need Pic
Yea, the ones that flip bow 2 up.
I tightened the nuts down because they were loose and nuts were missing. First time I went to flip the top down, I bent them.
Trying to bend them back. Is there tension on them, and thats what flips bow 2 up?
Old Apr 8, 2008 | 10:20 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Need Pic
Those nuts keep the rods in place so they lift the bow up when folding the top down. If they bent, there may be a problem elsewhere. The nuts on mine also came loose so I replaced them, and no issues yet, and it's been almost a year.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
