leaks !!!!!
Old Jul 3, 2008 | 05:15 AM
89 droptop's Avatar
leaks !!!!!
do our car leaks when it rains is there a way 2 fix my weather stripping is in good shape leaks at back of the windows when it poors
i drive my camaro and i get caught in the rain lol it happens!
Old Jul 3, 2008 | 07:56 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: leaks !!!!!
Mine does the same thing. I am taking the door panels off to replace window motors soon, so I plan on trying to adjust the window guides at the same time to see if that helps. But I don't drive mine in the rain much, so it doesn't matter a whole lot.
Old Jul 3, 2008 | 11:00 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: leaks !!!!!
Mine does there a little when I get caught in heavy rains. It's not much, maybe a few drops that easy to wipe dry. My roof, body and seals are all like new. The main hinge point for the roof (bottom back of the door windows) is the most difficult place to seal. There's like half a dozen contributing factors in that area that make it really hard to prevent leaking (the roof hinges there, there's a transition from fender to door, there's a window, and the seat belt guide and tonneau cover are near by). That's a lot of stuff to contend with all within a few inches!!!
I'm not sure anyone (or very few) had that area never leak (unless they've never driven in hard rain). The best you can do is be sure everything is in top (no pun intended ) shape.
Old Jul 3, 2008 | 03:26 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Re: leaks !!!!!
ive got a small leak at the front of the top where it meets the windshield and door window. the window isnt tight enough against the top, prob due to body flex. thats my only leak.
Old Jul 3, 2008 | 03:55 PM
89 droptop's Avatar
Re: leaks !!!!!
i try not drive in the rain but something i get caught (it sucks having my winter beater insure 2 drive on rainy days waste of money) is there any way 2 adjusted the seals at the top the bottom hole does not make that much mess it comes in like a stream when it rains hard at the top back of the windows. maybe the windows need 2 be twicked ? is there any tricks 2 adust the windows.
i had a 85 ttop that leaked in the same spot 2 maybe it just my luck
if i didnt like the like for my thirdgen so much i would sell it and buy and 4 gen ss twice the car!!!
Old Jun 29, 2009 | 04:05 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: leaks !!!!!
any updates?
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
