visor supports
Car: 1991 Trans Am convertible
visor supports
Do all third gen sunvisor supports work on convertibles or do they have to be for TTops?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: visor supports
Sunvisor Supports?
ARe you talking about the Spring with the Arm that goes into the visor itself? Those I want to think are the same for all 3rd Gens. The Visor is obviously different from the T-top to the Hard top. The T-top and Convertible uses the same Visor.
John
John
Re: visor supports
The springy thingos that mount to the car with the sharp bits that stick into the visor. Im sure the visors are different not sure about those thingos.
Car: 89 Iroc Convertible
Re: visor supports
I believe they are different.For a vert I would use the mounts from a t top car
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: visor supports
If you compare them the t top visor mounts are triangular where as the coupe visor mounts have a flat edge.Thats why I say they are different
Axle/Gears: 3.45, 3.27, 3.27
Re: visor supports
You'll need the sunvisor base from a GM F-Body t-top car.
Lon
Lon
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
