Sub Frame Connectors are in... WOW
Old Apr 26, 2009 | 09:22 PM
Scooby Doo's Avatar
Car: 92 Trans Am Convertible
Engine: 5.0L
I purchased the Alston SFC and a Wonder Bar from Lon at Top-Down Solutions www.top-downsolutions.com 626 369 0040 and they are awesome.
I had Certified Performance at 2900 Woodson 314 423 1663 Weld them in and throw on the Wonder Bar while they had it on the lift.
It made a huge difference I could not believe how much it tightend up the car, it was amazing.
Old Apr 26, 2009 | 09:28 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Sub Frame Connectors are in... WOW
holy *****, thats a nice car...
underside looks amazing.
should have gone with black powdercoat, but thats just my opinion.
looks great
Old Apr 26, 2009 | 09:47 PM
Scooby Doo's Avatar
Engine: 5.0L
Thanks, Color did not matter to me, this is a daily driver, so if anyone sees the underside of my car again it is either because I did something under there or I am in some serious trouble.
When I ordered them Lon said what color, I said I don't care send me what ever you have more of, he said red and I said fine, my car is red.
When the guys were welding them in I told them if they did not have red paint to paint the weld just use black, again, daily driver.
Now if I had put them on this car they would have been black, and I would have been more picky about the install and paint job.
Old Apr 27, 2009 | 02:01 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Great pics man! Very nice looking car too. If you could give a % wise as to how much the car tightened up, I would appreciate it. My buddy has a vert and he's still on the fence about sfc's. Thanks.
Oh yeah, I envy your clean underside
Old Apr 27, 2009 | 06:05 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Hey! Those look familiar hehe! Yeah the ride is much better, better cornering and much less twist on take off. % wise type numbers .... I dunno, 75% less body twist and 50% better cornering? Maybe 75% as well? Hard to say/guess. There is much less body tilt/roll on corners.
I took it for a spin (if people in the Toronto area know this area - you know how winding this road is) through Forks of the Credit which literally has an uphill hairpin turn. I usually loose traction on the second turn going uphill (just one tire slipping a little) and this time it didn't. But that was only one go at it.
Old Apr 27, 2009 | 12:16 PM
Scooby Doo's Avatar
Engine: 5.0L
I don't know % but I would say this might be the best mod I've done.
Sometimes you do things, and after it is like, well I think I can tell a diff, this one was obvious just sitting in the car, first turn was like wow, the front and the back are working together now instead of going in different directions.
Put it this way, if I were to ever get another vert, and it did not have these, these would be the first thing I would add.
Old Apr 27, 2009 | 03:35 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I have the same mod also on my 91 vert. I am also planning to add Sphon connectors to the sill area or make up something of my own. After driving a car with tough connectors down the side and attaching to the center, I want to do that little bit more to increase the stiffness.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
RS Reaper
Sep 27, 2015 07:04 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Lanz06
Sep 14, 2015 07:16 PM
WickedBowtie
Sep 11, 2015 11:24 PM
