changing the convertible top
Old Aug 15, 2009 | 12:59 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Hey all
i believe i may be trading my 91 Z28 to a guy for his 92 Z28 convertible heritage ed. and a 92 RS. The convert is a project started and not finished. he said it will need a new top on it. Ive been talkin to a few friends and they say its a bi*** to put on. I seen on ebay i could pick one up for 3-400 or so. I just thought I'd see what you all thought about it. im not to familiar with converts so im glad thirdgen has a convertible section.
Old Aug 15, 2009 | 01:33 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Re: changing the convertible top
just realized there was a sticky on this procedure....have many people on here done it? is it easy to do with the instructions?
Old Aug 15, 2009 | 02:54 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
It's not that bad. You can get a top from topsonline for around, actually under the ebay prices. They carry wear pads also which will probably be needed (they were on mine anyway) and also the side tension cables. other than that some weldwood gel adhesive and you are set (oh and a lot of small cheap plastic spring clamps. not rocket scince just make it look the way you want I just put them on somewhat tight and then they shrink from the sun too.
Old Aug 16, 2009 | 10:58 AM
mikeiaz's Avatar
If you have never done one or have never done upholstery -personally I would not do it. If you want the car overall to b e nice it would be a shame to have a new but poorly fitting top, or worse one that got damaged during install. Make sure you check the condition of the top weatherstrips - at a minimum with a new top you will need a new rear bow to tonneau seal (they run $100) - all these weatherstrips for the converts are priced like they are made from solid gold - if you need a full set it will run you in the neighborhood of $600. ALso check the condition of the plastic trim covers at front top bow interior sided and windshield to ointerior side - if these are original they are liukely cracked or at least very brittle, replacements will run you $200 to $300 for both pieces.
Old Aug 17, 2009 | 10:22 AM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
mike where have u seen the trim that goes behind the latch handles not the one on the top of the windshield i need one but i have never seen a new or repop
Old Aug 17, 2009 | 11:04 AM
1Aauto's Avatar
Former Sponsor
I haven't installed a top on one of these cars.However if you need a new one,ours are made in the USA and the quality of them is very good.
Here's a link to them on our website.
Camaro Convertible Top
Also here's the way to properly measure your top.They're a little tricky on these cars due to the conversions being done by third party companies.
Attached Thumbnails changing the convertible top-87-92-f-top
Old Aug 17, 2009 | 12:58 PM
mikeiaz's Avatar
as far as I know the only one currently reproduced is the on on the top of the windshield - if you need the one on the front top bow you need to try and find a good used one
Old Aug 17, 2009 | 05:27 PM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
yeah thats what i though mine has a small crack where one of the screw go when i get a new top i'm definatly going to get the cables and pads at the same time probly going to try out the glass also guys at 1a are pretty cool i called and asked them about a door panel color/fabric scheme that they did'nt show but said they could do any combo i wanted even sending me sambles of the coler so i can see what it looks like.
Old Aug 18, 2009 | 09:26 AM
mikeiaz's Avatar
ok here is what I did for mine: remove the trim piece and clean the back side, scuff around cracks and screw holes.; I got very thin washers that were large enough hole to accomodate the screw size then I epoxied them on the back side to reinforce the screw holes. If there were small cracks i glued them first with super glue, then on back side over the crack and around the screw holes I used some body repair mesh as reinforcement and then spread epoxy over it. I used black wax ( actually shoe polish but I have also used black crayon) to help fill and hide the crack on the front side of the trim.
Old Aug 18, 2009 | 01:30 PM
Engine: 5.0 tpi
Axle/Gears: g92 b/w
cool thats a great idea with the crayon or wax i think this would be perfect to fix mine no more thinking about what to do about it.... i also think it will look beter in the end than tring to plastic weld it and duplicate grain and so on. i always seem to find myself hijacking a thread(or wanting to) sry stream
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
