Trunk release button
Old Aug 31, 2009 | 05:24 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Behind the shift lever is the button that slides forward and back. I think it releases the rear hatch on coupes. It was inop when I bought the car so I'm not sure if it is supposed to open the trunk in a vert or what. can someone tell me what it does in a convertible?
If so, is it electrical or attached to a cable or what? Thanks.
Old Sep 1, 2009 | 10:23 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Re: Trunk release button
That switch operates the tonneau release. After rasing the rear of the top off the tonneau you press this switch and it fires the releases and allows the tonneau cover to rise.
Speedy
Old Sep 1, 2009 | 11:19 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Hes right, but mine doesnt work either. I *think* i traced it back to the solenoid 'poppers' being bad. They're behind the panel that holds the rear speakers.
Old Sep 1, 2009 | 12:00 PM
IRCZ's Avatar
My solenoid poppers are bad also....anyone have a good replacement.????? Thanks
Old Sep 1, 2009 | 12:12 PM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
have you guys tested you selinoids by putting power directly to them if not try that to isolate the problem a problem i have had a couple of times is a connector comming unplugged under hatch realease motor wich doesn't allow the tonneau to be popped if the trunk is open also it must be in park if at or parking brake applied if m/t
heres a link to the thread with the wiring diagram
https://www.thirdgen.org/forums/conv...ble-cover.html
Old Sep 1, 2009 | 12:57 PM
Car: '90 RS Vert
Engine: 305 TBI
Tomclayborn beat me to it.
This is not an un-common occurrence in our cars. There is an interlock at the trunk latch that prevents the tonneau being popped while the trunk is open. If this were to happen expect to spend some dollars for paint to repair!
If you are standing at the back of the car looking down at the trunk latch there should be a wire plugged into the bottom of that latch a little more toward the left of center. If this is loosely coupled or disconnected your tonneau will not pop. you can test this by installing a loop between the two connectors that would eleminate the trunk switch from the circuit.
I danced a jig when I finally figured out why the trunk solenoids were not working!
Good Luck!
Speedy
Old Sep 1, 2009 | 01:44 PM
Good Luck!
Speedy
I, for one, am going out to my garage right now to see if I cant get em working. Thanks for the advice!!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
