something's not right here
Old Jul 11, 2010 | 05:36 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
I noticed a couple of things wrong with my 91 TA vert.
For starters, this cross beam (whatever it's called) is not touching the window frame (vocab?) unlike the driver's side.
You can actually see on the outside how the left is a little higher than the right:
How can I adjust it to be even?
And this side is even like it should be I'm guessing. However that little rod rubs against the bolt and creates an annoying squeak. Is it ok if I just bend that rod out of the way or is there a "right" way to fix this?
Thanks!
Old Jul 11, 2010 | 07:54 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: something's not right here
You think YOUR top is bad? You should see mine! lol
Sorry, no help here.
Old Jul 11, 2010 | 08:04 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Dont bend the rod I looked at mine ,the part that is not touching should be as you had mentioned .There must be a way of adjusting, perhaps your missing a screw that may have come out explaining why its up and your rod on the other side is rubbing
I checked mine and they are flexible I can move mine up by hand but it goes right back to its original position as soon as I release it(cross beam).
Mine has a headliner so its difficult to see( Im sure I could remove it but havent tried yet)
Old Jul 11, 2010 | 11:18 PM
zuma's Avatar
Car: 1969 SS Camaro, or 1990 Iroc vert,
Engine: 350 and 305
Transmission: tb350 and 700r4
I had the same problem with mine,I don't really remember exactly what I did except that I bent that smaller rod until that angled piece sat on the main side frame...fits pretty good now...
Old Jul 12, 2010 | 03:25 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
where it squeeks, why not put a small piece of rubber to insulate it?
Old Jul 12, 2010 | 03:56 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
yeah and it should raise it up too.
Old Jul 12, 2010 | 04:51 PM
irock88's Avatar
if you compare the rod location on both sides to the bolt that its rubbing against it does look as thou the drivers side needs to be raised up or bent up
