ASC sticker
Old Dec 22, 2010 | 07:19 AM
marvinwhite's Avatar
Car: 1989 RS Convertible Camaro
Engine: 5.7 LT1
Transmission: 4l60E
ASC sticker
I’m trying to remake the ASC sticker that was on my door jam. It was in bad shape and removed a couple of years ago for a new paint job. I have the logo and information that’s supposed to be on the sticker but I don’t know the height and width of the sticker. It looks like the size has changed over the years, so I need to know what size they were in 1989. After I make the sticker I plan on putting a clear vinyl on it so it will last a lot longer.
Marvin
Old Dec 22, 2010 | 11:46 AM
Drew's Avatar
Re: ASC sticker
You might want to dig around a bit... The market for thirdgen restoration parts is pretty small, but ASC did more then just thirdgen conversions.
http://www.ascmclaren.com/nameplates.htm
Old Dec 23, 2010 | 02:32 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Re: ASC sticker
My 89 GTA vert ASC sticker is 4-3/4 x 1-3/4 square corners mounted horizontally under the door striker.
Old Dec 23, 2010 | 06:58 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
Re: ASC sticker
that web site is perty cool i thik im abot to order one for me. my car is going to get painted some time next year and my sticker is have off
Old Dec 23, 2010 | 07:33 PM
Engine: 5.7 LT1
Transmission: 4l60E
Re: ASC sticker
OK thanks, I made one 3 1/2 by 1 1/2 that looks real good. I like the smaller size but I may make it a little bigger to keep it more like the orginal. To simulate the date stamp I used a bigger font and bold print.
Old Jan 12, 2011 | 07:18 PM
BRG91's Avatar
Car: 91 Firebird Convertible
Engine: 305 TBI
Transmission: Automatic
Re: ASC sticker
My sticker is still there but it must of had an air bubble behind the left side cause it looks like someone put a paint splotch on it when in fact its got a hole in it. Maybe should look into replacement.
On a seperate note: if I use the ASC website can they also possibly confirm my top and rear window being original or replacement ?
My rear window has a pressed in logo that says KAL GLAS and underneath DOT #138 AS-6-M-176
D 2335 With a - Do not rub dry
wash with water soacked cloth.
Any thoughts on this being replacement or orignal ? Car has 84K and is north east seasonal use of lateer years.
Old Feb 13, 2011 | 03:44 PM
appiebroomer's Avatar
Re: ASC sticker
Hey Marvin,
Would you post a photo of your reproduction, or could somebody else post a photo of a real ASC sticker. The sticker on my 89 is missing as well. I could then make one in photoshop.
Old Feb 13, 2011 | 06:46 PM
Engine: 5.7 LT1
Transmission: 4l60E
Re: ASC sticker
Send me your email and I'll send you the one I made and a old sticker from another camaro.
Old Feb 13, 2011 | 07:57 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: ASC sticker
For BRG91 - After the "DO NOT RUB DRY - WASH WITH WATER SOAKED CLOTH" on the rear window, there should be a number like D-91. That tells you it is a 1991 window but does not insure it is the original.
Old Feb 14, 2011 | 01:06 PM
Re: ASC sticker
baljeu@sympatico.ca
Old Feb 15, 2011 | 05:40 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: ASC sticker
Originally Posted by appiebroomer
Hey Marvin,
Here's mine of my '89. It's probably not good enough to reproduce without heavy photoshopping. I did post it to help others know what we're talking about.
Old Feb 15, 2011 | 03:07 PM
Engine: 5.7 LT1
Transmission: 4l60E
Re: ASC sticker
I finally learned how to post a picture from another website so here is the one that I made for me.
Old Feb 15, 2011 | 04:54 PM
Re: ASC sticker
Thanks guys.
Old Feb 15, 2011 | 06:12 PM
Re: ASC sticker
Old Feb 15, 2011 | 06:14 PM
Re: ASC sticker
Old Mar 1, 2011 | 07:00 PM
Re: ASC sticker
HI IROCTOPLESS,
The vin# on my 89 vert is close to yours 1G1FP31F7KL127168. My Service Parts Identification label (the one inside the glove box) is also missing. Would you have a photo of yours. I want to try to reproduce one.
Al
Old Mar 3, 2011 | 02:13 PM
Axle/Gears: 3.08
Re: ASC sticker
The VIN doesn't tell you much more than the basics. Options can still be quite different. But you might be able to pick and choose what might work for you. Either of us could still have a number of RPO's that the other doesn't have. These are my best pics of it. Mine is also a Canadian car. If yours isn't, it will have a few different RPO's than yours (example Z49 for Canadian export, etc). I've also included a dealership RPO definition report explaining most them. Good luck.
Mounted location . . .
Close-up . . .
Dealership report - page 1 . . .
Dealership report - page 2 . . .
Old Mar 3, 2011 | 05:38 PM
Re: ASC sticker
Thats great, much appreciated.
Thanks Again.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
codeysabatini
Nov 10, 2015 04:07 PM
Linson
Oct 1, 2015 05:33 PM
okfoz
Sep 15, 2015 05:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
