New top install
Old Dec 27, 2010 | 06:17 PM
TUCK1975's Avatar
Car: 1992 firebird vert
Engine: 355 soon to be a 406
Transmission: 700r4 goin t5 then t56
Axle/Gears: 373 or 410
New top install
was wondering how hard it is to replace the top on my 92 bird vert my back window is broke and i really cant afford the $1000 to have the top replaced by someone else. so i was wondering if anyone has done it and if its way to hard for the average diy kinda thing any suggestions would be great
Old Dec 27, 2010 | 09:02 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: New top install
I have used this write up with some success
http://sethirdgen.org/convertibletop.htm
the difficulty level all depends with how comfortable you are with this type of work....
Old Dec 27, 2010 | 10:46 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
Re: New top install
It wasn't too bad... Took about a day with installing new seals. I used the Topsonline.com stayfast with glass window. Fit and quality is excellent.
Old Dec 31, 2010 | 12:39 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: New top install
i replaced my top with one from tops on line. the install was easy. i used the link posted above as a reference. get a can of contact cement from lowes or home depot, and a few brushes. take your time and youll be happy.
Old Jan 1, 2011 | 10:59 AM
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
Re: New top install
Thanks for the link, it will make life easier this summer when I replace the top on our vert.
Old Jan 3, 2011 | 03:59 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
Re: New top install
I did mine myself for the first time and had minimal problems other than replacing the pads. Topsonline directions weren't very good, but common sense prevails.
I needed to replace the pads and the problem I ran into were the original pads had loops in them to slide over the rear bow, and the replacements did not. I wound up riveting the pads to the rear bow and wrapped the pad around one time to cover the rivet heads. If I had to do it over again I would have had the loops sewn in the new pads at a local upholstery shop before starting the project.
Frozer!!!
Jan 19, 2024 04:55 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
69 Six Pack
Oct 5, 2015 07:51 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
