91 RS Convertible speedometer not working
Old Jan 9, 2011 | 07:48 AM
mcguffey4's Avatar
Car: 1991 Chevy Camaro RS Convertible
Engine: 5.O/305
Transmission: Automatic
does anyone know what i should do, everything works but the moh on my gauge i have changed them out twice ab=nd the same problem persist. any ideas.
Old Jan 9, 2011 | 09:37 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: 91 RS Convertible speedometer not working
yes, put a computer on it, and see if you can read how fast your computer thinks your going.
if the computerdoesnt get a vss signal, there is probably a problem with your sensor or the wire going to the computer and speedometer.
if your computer get the right signal, its proably the tach, or the wire running from the speedo.
Old Jan 9, 2011 | 08:06 PM
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
Does the odometer work?
Old Jan 10, 2011 | 10:16 AM
mcguffey4's Avatar
Engine: 5.O/305
The only thing that has been working on both the new one and the old is : temp, batt, cooling, oil press
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
