gas door cup
Old Jun 18, 2011 | 12:20 PM
chuck76's Avatar
Car: 1988 convert camaro
Engine: 305 edelbrock performer cam,intake
Transmission: 700r4 shift kit,vett servo,3,4 pack
Axle/Gears: stock
gas door cup
were the convertibles plastic cup that goes around the gas cap different from other camaros.mine was missing when i got the car and i when and got one from a non covert and it didnt fit if so im needed one thanks
Old Jun 19, 2011 | 11:26 PM
JT's Avatar
JT
Community Administrator
Re: gas door cup
Maybe an expert will know for sure, but I could not find any special part in the Firebird Parts & Illustration manual under the Convertible section. Sorry, I don't have a Camaro one but a part like this is probably the same. Thus, it would appear to me to be the same part.
The book shows that all 1982-1992 Firebirds had the same pocket (10077471), unless the vehicle had the locking fuel door option. If the locking fuel door option, it does appear the pocket had a different part number.
Old Jun 19, 2011 | 11:33 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: gas door cup
AFAIK they are the same. The one on my 'vert looks just like the one on my coupe, but I haven't pulled it out to check the number.
Lon
Old Jun 20, 2011 | 07:36 PM
chuck76's Avatar
Axle/Gears: stock
Re: gas door cup
i was thinking it was missing been awhile but its there but cut up in back.the one i have that was to replace it has the #'s 20215476 70050-82
Old Jun 24, 2011 | 11:49 AM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
Re: gas door cup
Here is what I've found on both my 'verts while changing the fuel pumps. As we know the upper inner fender was replaced with a new structure to allow for the top storage. This intruded into the area for the fuel filler cup. On both cars the cup has been cut in the back to fit the contour of the inner fender (I assume by ASC) and were left open. Cuts are rough with plastic burrs hanging from them, and are both different. I think they were cut on a bandsaw for each individual car.
Old Jun 24, 2011 | 12:15 PM
chuck76's Avatar
Axle/Gears: stock
Re: gas door cup
thanks for the info guess i got some cutting to do
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
mustangman65_79
Aug 13, 2015 07:36 AM
