Max horsepower on cab.
Old Aug 15, 2011 | 12:25 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi!
How much hp have you put in a thirdgen trans am 90-92 cab?
I am running about 380rwhp today and planning to go another 75 nitroz,to much ?
Old Aug 15, 2011 | 10:53 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: Max horsepower on cab.
I don't see any subframe connectors mentioned in your mods. That needs to be #1 on your list of mods before you add any more ponies!
Old Aug 18, 2011 | 04:55 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I probably made 750-800 to run 9.80's @ 3550lbs.
Old Feb 8, 2012 | 06:44 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
AutoRoc,what had you done to the chassi and what rear axel did you have,i am going to put in a 383 and a new cam and som subframe connectors.
Did you do anything to get the car lighter?
Anders
Old Feb 8, 2012 | 09:09 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Originally Posted by Firebird sweden
Ok
Anders
auto roc put a 6 pt roll bar in his car, which i would highly suggest. It will bring a lot of the flex out of the car. I am currently having my fabricator build me a 6 pt chromoly roll bar with swing out bars and a X brace. I think i should have my car back at the end of the month, but no promises.
Old Feb 9, 2012 | 12:36 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
I already have a 4 point rollbar,maybe i should put on 2 more links to it.
What cind of rear axel do you have?
The car is going to be a street/race car and about 500fwhp and a 100 hp noz.
Old Feb 9, 2012 | 09:41 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
man a 4 point roll cage will help you alot it took a ton of flex out of my car I can open the doors with the car jacked up now
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
PurelyPMD
May 5, 2016 04:57 PM
Gordonr1973
Sep 29, 2015 11:59 AM
dbrochard
Sep 25, 2015 04:56 PM
CatmanFS
Sep 19, 2015 09:00 AM
