89 z28 vert worth it?
Old Jan 13, 2012 | 08:40 AM
1 bad87z's Avatar
Car: 87 iroc-z & 88 vert
Engine: 350 tpi & 305 tpi
Transmission: 700r4 & tpi
Axle/Gears: stock & 308 posi
89 z28 tune port motor with 5 speed blue with a black top guy wants 1600 for it needs floors patched and interior put back in
Old Jan 13, 2012 | 11:40 AM
chico3371's Avatar
Car: 87 z28
Re: 89 z28 vert worth it?
That is what I paid for mine but mine is 87. It's worth what you wann a pay for it. looks nice and if it's runs it's worth the money
Old Jan 13, 2012 | 01:42 PM
1 bad87z's Avatar
Ya it runs and drives has new shocks struts and lowering spring it looks pretty good
Old Jan 13, 2012 | 02:11 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
no brainier....yes. Get that stock hood that is painted the same as car too. For a little time and effort it would be a nice car. Not that many 89's built. I would pay that for it no problem.
Old Jan 13, 2012 | 08:04 PM
lt1zr28's Avatar
The hood alone should bring $350-500 if you want to go back stock.Can't tell
from the pics if the other is the stock hood? Definitely should be worth asking price.
Good luck with it.Any Camaro that can be saved is worth savin.
Old Jan 17, 2012 | 01:05 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Can you get the VIN? Or better yet the SPID (the decal that should be in the console for an '89, that lists all the RPOs, make sure the VIN on the decal matches the VIN on the car), I'd be interested in verifying it's status.
Reason being, there's a few things that look suspect. All Z28's in '89 were IROCZ (trivia note). If he says it's the original TPI engine, then the eighth VIN digit would be an F for the LB9 305 TPI (the only TPI engine that was available in the Camaro vert and the only TPI engine that could get a 5 speed). If it has the F, then it would officially be an IROCZ. You can come to that conclusion because in '89 the Z28 RPO option got you the IROCZ, and only the Z28/IROCZ's got a TPI engine.
The suspect things is the striping is missing (could have been an option delete and/or repainted), the original wheels are missing, the badge behind the front wheels looks like it belongs to the RS model (hard to tell 100% from blurry pic), the grill looks like it belongs to an RS and also no fog lights like the ones that come on the IROCZ (might have been deleted). All of this, plus whatever else that can be changed over the years (like engines being swapped, other parts, etc), would make me pause and confirm what the car actually is.
Old Jan 17, 2012 | 01:20 AM
Axle/Gears: 3.08
PS; I just read your later post and it looks like you bought the car. She definitly has the TPI (pretty obvious ). Looks like a great project car. Good luck with her.
CAMAROBEAV
European Region
Apr 29, 2021 04:54 PM
Orr89RocZ
Sep 13, 2015 09:41 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
dementednut
Sep 10, 2015 09:50 PM
