Convertible headliner??????
Old Oct 3, 2012 | 08:24 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
So I know some later convertibles had a headliners in them. Any one have pics of the headliner that came from asc and where can you get one ? My car didn't come with one
Old Oct 4, 2012 | 12:28 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Convertible headliner??????
I would like to know where you get one myself since my 92 has one that I will be replacing soon when I install my new top.
Old Oct 4, 2012 | 06:06 PM
BADNBLK's Avatar
COTM Editor
I think Topsonlines sell a headliner kit, but states that its only for used for vehicles originally equipped with one. I bought my top there, but did not buy the headliner kit. I washed my headliner with soap and a hose
Old Oct 4, 2012 | 06:28 PM
Benc1's Avatar
I'm contacting topsonline to see why it won't fit older cars
Old Oct 4, 2012 | 06:47 PM
Benc1's Avatar
Can you post some pics of the headliner?
Old Oct 4, 2012 | 07:52 PM
BADNBLK's Avatar
COTM Editor
I don't have mine back together, but can take pics of the two parts and what it looks like installed.
Old Oct 4, 2012 | 07:56 PM
Benc1's Avatar
That would be great.
Old Oct 4, 2012 | 07:59 PM
Benc1's Avatar
Here is the reply I got from topsonline.
Hi Ben,
89 model does not have the required attachment points from inside in order
to attach a headliner, I personally don't recommend installing a headliner
on 89 model, since your car was not equipped with one it may rip while
raising or lowering the top or the plastic attachment that snap on the top
frame from inside might come lose also while raising or lowering the top.
Thank you
Vic
Now I gotta see what he's talking about
Old Mar 10, 2013 | 12:44 PM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
If you swapped a later model frame could you install a headliner?
Old Mar 10, 2013 | 02:20 PM
Benc1's Avatar
Sure you could.
Old Mar 10, 2013 | 04:35 PM
abray1's Avatar
It would be nice to see the difference between the two frames to see if they just welded some tabs to the same frame.
Old Mar 17, 2013 | 10:04 PM
hotrodder355's Avatar
Car: 1991 RS Convertible
Engine: 377 w/Holley Commander 950 EFI
Axle/Gears: 2.73:1 with Auburn Posi
I have a 91 vert with a headliner. I got my top and new headliner from electron top...probably the best quality stuff I have ever seen. According to electron the only way to have a 3rd gen vert with a headliner is to have a top with a headliner from the factory. I guess the frame is different because when I went to order and said i needed a headliner they asked if it had a factory headliner. I said it did and they knew exactly top what to send. They said all tops with a headliner take certain part numbers.
Old Apr 13, 2013 | 04:17 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
I believe the later tops, had a different bow towards the back, to give more headroom for the rear seat passengers. Could that be part of the difference also?
Old Apr 15, 2013 | 07:08 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If memory serves
86-88 Narrower top
89 - Unique
90-91 - Almost identical to the 89 top, but has headliner provision
92 - similar to 90-91, but has a different attachment point behind the doors, something like 3 bolts vs 2 bolts..
If I remember correctly, you can install a 90-91 on a 85-89,
I would not take my word for it, but it is to the best of my recollection.
John
Old Apr 15, 2013 | 07:46 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
My 90 Iroc has a head liner, some of the attachment points are velcro on sides. Liner is falling down on front corners by the latch handle.
Just picked up a semi project Iroc 90 vert ... still learning.
Old Aug 27, 2025 | 08:30 AM
neilcase's Avatar
Car: 1987 IROC-Z convertible
Engine: 5.0
Transmission: 700R
Axle/Gears: 2:77
Originally Posted by okfoz
If memory serves
86-88 Narrower top
89 - Unique
John
This is incorrect. You can NOT bolt a frame from late 88-92 onto an 86 thru early 88 because the front bow latches are totally different.
86-thru early 88 - twist in style front latches. This changed in late 88 to a rotating tab style latch and the frame got one inch wider at the top bow.
then in 91 they added the headliner which changed the 4th bow slightly and added some additional small attachment provisions for the headliner.
but the answer to the question is YES, you could bolt a 1991-92 frame with a headliner onto a late 88 thru 92 car. But not an 86 thru early 88 car.
Old Aug 28, 2025 | 10:11 AM
okfoz's Avatar
Thank You for the clarification.
John
Old Oct 12, 2025 | 11:01 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Well, since this thread has been revived. My 89 has a headliner and has the original top frame. My friends all original 89 has it too. He had a custom HL made from real suede I went cheap and made mine from faux suede (but he copied me though ).
The frame has small velcro squares above the window seals and the old liner had velcro strip i think, but it didn't stick anymore. I didn't bother replacing that when i made mine.
marcus88
Convertibles
Jun 13, 2008 08:43 PM
