Arrggh wrinkled the back window good
I broke a bolt on the top a few weeks ago and left it down for quite a while without thinking. I fixed the bolt today and put the top up. Ouch. Major wrinkles in the window, and a line almost in it from being folded. I have been sun bathing her all day long in 80 degree heat, seems a little better, but I am concerned. Any advice?
Thanks!
Thanks!
Engine: 4++,350 & 305 CIs
Re: Arrggh wrinkled the back window good
Keep it warm, it will come out with time.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
a stemaer wrapped in a towel applied very shortly to not burn the vinyl works. or use the towle over the steamer, a sprits of water on the whole topp and barely touch the steamer to the top. too long at the vinyl will melt and itll look crappy.
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Try a hair dryer. They don't put out as much heat, so less chance of melting your window. Move it back and forth across the fold, and it should smooth out.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
