Lubricating Vert Frame
Old Sep 17, 2013 | 12:50 AM
pontiac_4_ever's Avatar
Car: 1991 Trans Am Convertible
Engine: 5.0 TPI
I was wondering if anyone had oiled or graphited their Vert metal framework? Mine works well but I have noticed that the top goes up and down a little harder than I figured it should. I noticed that all the wear points on the metal framework appear to be dry.... I was just wondering what other Vert owners do, do you oil it or let it be? I want to make sure the framework lasts as long as possible as the I have found out the parts are NLA and hard to come by.
On another note.... I am looking for the small metal bent brace that hooks the frame together on the right side, I think its called (no. 2 bow actuator) if anyone has one for sale please pm me.
Thanks!
Pontiac_4_ever
Old Sep 17, 2013 | 05:50 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Lubricating Vert Frame
I don't have a 3rd gen convertible, but I do have a 4th gen convertible. I use white lithium grease and apply it in the hinges with a Q tip. I would be careful about applying too much lube. You wouldn't want it to drip on the interior when the top is up on a hot day.
Old Sep 17, 2013 | 10:20 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
White lithium grease does wonder for lubing stuff up
Old Sep 18, 2013 | 12:59 AM
Engine: 5.0 TPI
Thank You! I will try that this weekend.
okfoz
Oct 13, 2015 02:19 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
