Trunk Latch Pull Down
Car: 1991 Z28 Convertible
Engine: 5.0 TPI
Transmission: 5 Speed
I recently removed my seats to replace them and I found a couple of wires coming out of under the carpet a hot ground and a hot with a built in fuse. I thought the previous owner had installed an amp or stereo as the wires went into the center counsel? Anyways I opened the trunk a few days later and now the pull down mechanism no longer works? Did ASC rewire the pull down mechanism when they added the switch to the tonneau release button. Any help is greatly appreciated.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Trunk Latch Pull Down
They may have. They re-routed the hatch release switch to release the tonneau, so there might be a little more going on there...
John
John
Axle/Gears: 3.45, 3.27, 3.27
Have you unplugged the blue wire from the red/white stripe wire and tested the red/white stripe wire for power?
Lon
Lon
Engine: 5.0 TPI
propaintball96
Nov 23, 2015 02:07 PM
