Fliprods
Old Feb 13, 2019 | 11:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Fliprods
Or whatever their name is.Anyway, mine were binding some/elongating the hole a tiny bit & one was repaired/welded prior.So anyway, i modified another damaged pair i had.i swear it feels smoother with them little heim joints.One welded, one threaded for adjustment to fit.Easy mod btw.
Tried taking a pic with it in top down mode.No interference issues.
Old Feb 14, 2019 | 10:40 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Fliprods
Man, that looks good. When I bought my car something like 15 years ago I replaced the broken flips rods with ones from TDS and I think they broke again in 6 months. I decided it was easy just changing how I dropped the top and lifting from the second bow I've never had an issue. That and I stopped putting my top up more than like three times a year. Haha.
Nice job!
Old Feb 14, 2019 | 05:23 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Fliprods
Good idea. Bearings are always better for rotational things like this. Sorry GM could not afford them on all the tops.
Old Feb 14, 2019 | 05:28 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Fliprods
Thanks guys. I saw TDSs & was gonna buy them, but then i got cheap and decided to mod what i had.
Old Feb 14, 2019 | 08:08 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Fliprods
Lon at TDS redesigned them a couple years ago. The ones he sells now are pretty legit. He even heat treats them so that the rods are stiffer and less prone to bending.
Old Feb 15, 2019 | 07:14 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Fliprods
That's pretty slick, nice work!
Old Feb 15, 2019 | 04:53 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Re: Fliprods
I'll keep that in mind as I replace the top in a few months. Its good to know something better is available.
