Vert third brake light same as non-vert?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
The previous owner smoked it and I want to replace it with a stock one.
Re: Vert third brake light same as non-vert?
Did you search? Because I answered this question not too long ago.
They're the same aside from the years that used the small Ford 3rd brake light. Firebird convertibles used the same lights as Camaros too, fwiw.
Engine: 350 TPI L98
Transmission: WC T5
Yes, I tried searching. Thanks, so any other than the smaller ones should fit in there. Good to know.
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
I had asked the question a few years back, as someone had hacked a normal GTA CHMSL into the convertible lid, from a coupe. It was bad.
Here's the thread:
https://www.thirdgen.org/forums/conv...ird-brake.html
Here's the thread:
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
If its just that they smoked it with that "spray tint" you could always remove the "smoke" - wet sand with 1000 then 2000 grit and then polish with polishing compound and then a car wax. I did this with a pair of tail lights years ago which were "smoked" and they turned out fantastic, not too much work - I believe that was the progression I used if I recall correctly.
twiztidz28
May 3, 2002 06:17 AM
