Removing Top & Frame from Vehicle
Old Feb 12, 2024 | 05:35 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I am planning on a body re-spray. I want to remove as much as possible before sending off to the body shop. How challenging is it to remove the top frame and top from the vehicle? Is it a matter of removing the bolts from the big brackets in the trunk area, anything else? How hard is it to align afterwards upon re-install? I am familiar with some basic panel alignments after removing panels for paint - ie marking current locations as a guide reference before removing, but curious regarding the top. Any suggestions are much appreciated.
Old Feb 17, 2024 | 07:31 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Removing Top & Frame from Vehicle
It’s only held on by the rear bolts.Once you remove them you can lift the frame right off
Old Feb 17, 2024 | 08:19 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Perfect, thanks for the response.
iroc stangs
Jun 18, 2010 10:03 AM
BOSS 357
Oct 22, 2005 11:44 AM
mdricken
Apr 22, 2004 02:39 PM
Doward
Nov 5, 2002 06:12 PM
original
Jun 27, 2002 05:09 PM
