Special rad hoses?
Old May 29, 2002 | 08:49 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Special rad hoses?
I had to get my waterpump replaced yesterday, after it blew it's gasket on it's backplate as I pulled into work. Damn thing, if it had crapped out at home (25 clicks away) I would've just fixed it myself. It's a '90 GTA, 305. Anyway, I asked them to replace the rad hoses while it's apart and mostly empty. Apparently the parts guy made a big deal about it and said the lower rad hose was some "special" and unusual hose for my particular car and wanted like $45 Canadian for it. Ahem, a special rad hose? For a bone stock V8 Trans Am? How exactly is this a rare setup? I told him to forget the hoses and just do the pump, since I didn't want to blow another unexpected $100 for the pair installed (ontop of the $300 installed for the pump, and whatever the hell I paid for the new rad about a week and a half ago). If it needs them I'll do it myself. What do you think, is there something special about this lower hose?
Old May 29, 2002 | 08:56 PM
Hulk0202's Avatar
The part isnt that expensive, but shops make a lot of money off parts. Do it yourself. Its easy and a lot cheaper.
Old May 30, 2002 | 12:51 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
I bought a whole set of high temp hoses a few monts ago. They are the goodyear ones and they came in blue so they look awsome. I bought the whole veh set and it cost no more them about 80-90 that includes the heater upper lower ect. I dont see how one hose could cost you so much sounds like a scam to me. If you interested jc whitney sells them they come in a kit for tbi or tpi.
Old May 30, 2002 | 10:16 AM
camaro6spd's Avatar
Just go to your local parts store and by one....bring it to them and be like i had one.....i do that all the time....i bring the parts to the mechainc....my IROC Convert was pushed off the road and into a curb...knocked the alignment out...it also bent a ball joint and elongated the hole in a spindal.....i just brougt over a spindel that i had...all i had to pay for was the labor and the ball joints and the alignment....
Old May 30, 2002 | 10:56 AM
NTChrist's Avatar
Yeah, the lower rad hose isn't anything special.
I think we even share hoses with Monte Carlo's, and maybe another GM smallblock car.
Definitely not worth $45 CDN for one hose.
Old May 30, 2002 | 05:32 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Like I said, if it had crapped out closer to home I would've fixed it myself. Half an hour over lunch isn't enough time to find a new pump and install it.
The quote was for the UAP Napa replacement lower rad hose, nothing fancy. A V8 Firebird requiring a special hose. Hell my 4.3L Jimmy probably uses a similar hose.
Ah well, thanks for the confirmation guys. I'll probably pick up a set somewhere and just save the untill I need them.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
92projectcamaro
Dec 8, 2015 12:25 AM
Thaney9
Oct 24, 2015 07:26 PM
Bradsaundry
Oct 7, 2015 04:35 PM
