Cooling fan operation
Old May 30, 2002 | 06:00 PM
383 rocket bird's Avatar
I placed a paper clip in between the A and B terminals to set my IAC and when I did one of my fans came on. I have the dual fan set up and I was wondering if both fans should come on? Only my drivers side fan came on. I just put the new motor in and I broke the sensor in the passenger side head and have not had a chance to replace it yet. Could this be causiong my problem? Any help would be great. Thanks guys
Old May 30, 2002 | 11:43 PM
breathment's Avatar
only one fan is supposed to come one when you do that. the primary fan... not exactly sure why though..
Old May 31, 2002 | 05:36 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is supposed to do that, it is part of the ECM's testing subroutine. The secondary fan is not controlled by the ECM, it is controlled by the switch in the block on the passenger side. That temp switch controls the secondary fan relay directly without any assistance from the ECM. I would replace it if it is damaged or you may regret it on a hot day in traffic. NAPA offers two different switches, one that turns on the secondary at the stock 238 deg. and one at about 215 I believe. They run about 20 bucks.
Old May 31, 2002 | 03:26 PM
Yeah I bought a new one when I was putting the motor back together but I hit it with a header and broke it. I am gonna reinstall a new stock unit and then wire up a togle switch to turn them both on. Thanks for the info guys
Fanatic1074
Oct 3, 2022 05:57 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ndndndnd
Sep 28, 2015 08:00 AM
