Air Conditioner
Old Jun 10, 2002 | 11:24 AM
TrnsmGTA's Avatar
Car: 87 Trans Am
Air Conditioner
I know this has probably been posted before, but my air conditioner is blowing out warm air, it's cooler than the air here in Mississippi, but it isn't cold, and i need some AC ! what do i need to replace for it to work properly?
Any help is appreciated.............
Old Jun 11, 2002 | 09:30 AM
WaynesRS's Avatar
Hello neighbor ! (Im from Louisiana) !
fine your low pressure switch , un-plug it , stick a paperclip in the holes , if your ac then works and blows cold air , its a bad switch .
Check to see if you compressor is running ? Let the car idle with the ac on , and see if it turns . It could even be some loose lines .
Do you have a very slow leak ? Maybe it needs freon ?
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Thornburg
Sep 12, 2015 10:11 AM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
