Fan question
Old Jun 12, 2002 | 07:25 PM
Ride4ME's Avatar
Fan question
Is our fan powered by a switch or the ecm? Cause my fan motor burned on the inside and since replacing it, it still doesn't work.
thanx in advance,
R.
Old Jun 14, 2002 | 01:42 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I'm pretty sure all tbi's are controlled by a switch. Mine's a '90 and is controlled by a switch. An easy way to make sure is to call Summit and ask if a new switch is recommened if you purchase the hypertech thermomaster chip.
Old Jun 14, 2002 | 11:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yes it is controlled by the switch in the passenger side head
Old Jun 15, 2002 | 02:43 AM
JPrevost's Avatar
Car: 91 Red Sled
Yeah, stock it's a switch in the head...but hopefully I'll be changing that. cough...source code....cough.
Old Jun 20, 2002 | 04:44 PM
Ride4ME's Avatar
How so I change it?
Just remove the valve covers or do I have to remove the head?
Old Jun 20, 2002 | 11:41 PM
Desert86Roc's Avatar
FYI, the fan relay usually dies before the snap switch. So if replacing it doesnt help...get a new fan relay. Also, if your old fan motor drew enough amps when it burned up, you could have fried the fusible link at the battery.
Old Jun 21, 2002 | 05:48 PM
Ride4ME's Avatar
well guys...
I drained my coolant in order to change my thermostat notcing
that I never even had one in there... and I refilled the system with
coolant and guess what??...
MY FAN WAS WORKING!!!!
But guess what else?....
I shut if off and tried to restart it then it DIDN'T WORK AT ALL!!!
What's the deal??
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
