stwert water pump question
Old Jun 18, 2002 | 01:30 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
should i go with a stage 1 or stage 2.. my mods are below..
Old Jun 18, 2002 | 01:32 PM
bbtaz97's Avatar
Car: 91 RS
oops.. her ya go
91 camaro RS
- 305 TBI
Mods: Performer TBI intake,lt1 cam , ported 305 tpi heads with k-motion valve springs and 1.5 comp cams roller rockers, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP 2400 tq converter, b+m trans cooler, white guage faces, megashifter,malloy billit pedals,taillight blackouts, centerline 16x8 rims, spohn lcas + panhard rod,lca relocation brackets,ls1 driveshaft, gm posi with richmond 3.23 gears.. it will be all done soon..
Old Jun 18, 2002 | 02:48 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Ask them, their tech support would be able to tell you which one would probably be a better option for you. Just from your mods, I'd say the stage 1 should be sufficient.
Old Jun 19, 2002 | 11:17 PM
iroc22's Avatar
You know what, stage one works very well. I'm sure stage two will work well for your application but all you would need is stage one. I would go with stage one.
Old Jun 23, 2002 | 09:24 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Yeah, but if you're a parts ***** like I am you get the Stage 2.
I also reccomend their modified thermostats, (manditory for Stage 2)
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
