hardwiring both fans together
Old Jul 1, 2002 | 03:27 PM
at8iroc's Avatar
Can both fans be wired together to come on when the first fan
comes on?I was going to splice them together down behind the
radiator.Will one relay run both fans?I know that the second fan comes on only when running the AC.Iwant both fans to come on
at the same time when the first fan usually does.
Old Jul 1, 2002 | 05:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Cut the 2nd fan green/white relay wire & splice it into the 1st fan green/white wire. Or just tie them into each other w/o cutting, doesn't really matter much since it's a ground anyways.
Old Jul 1, 2002 | 08:48 PM
at8iroc's Avatar
thanx to deadbird
Thanks alot deadbird for the info on the cooling fans.I will get on it
first thing in the morning.:hail:
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
