cooling fuel
Old Jul 2, 2002 | 10:29 PM
3rdgen327's Avatar
cooling fuel
something a little different. i am looking for ways to make a cool can for cooling my fuel. using dry ice. -109.3 degrees (F)
i have 2 ideals and wanted to see what others thought of.
Old Jul 3, 2002 | 11:29 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have a cool can in my 70 Nova SS 396.It's an old Mr.Gasket one.
Just an aluminum can with a coil of 1/2" aluminum tubing in it.
The tubing has tube sleeves/nuts and -8AN fittings and there's a drain petcock in the bottom of the can.
Moroso makes a nice insulated plastic one now, that has pipe-thread fittings in/out.
These things work great, the only reason I don't have one on my 92 RS is the lack of room in the engine compartment.If I didn't need to pass smog, I'd get rid of a few things and squeeze one in there.
The cold fuel makes a difference. I could feel the difference in my Nova the first time I used it. It has a 500HP 454 in it.
-Rich-
Old Jul 3, 2002 | 03:33 PM
3rdgen327's Avatar
did you use dry ice?
i am thinking of using a 2 lb. coffee can with 3/8" fuel line. putting a 13oz can inside of that to store the dry ice.
putting the line between the cans and filling it with expanding foam for insulation.
chazman
Aug 28, 2018 03:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
TheExaminer
Aug 26, 2015 04:59 PM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
