Looking for a hose
Old Jul 10, 2002 | 04:05 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
Looking for a hose
I've sprung a leak in a hose that is U shaped and runs from the top of the intake, close to the thermostat housing to the throttle body. Does anybody out there have a part number or an exploded view of this area of the engine? Also what purpose does this hose serve and can I get it anywhere other than ordering it from a dealership?
Old Jul 10, 2002 | 08:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
on what engine is this?
Old Jul 10, 2002 | 09:05 PM
clewis's Avatar
Car: 1985 IROC-Z
305 TPI
Old Jul 12, 2002 | 03:05 PM
breathment's Avatar
its probably just a heater hose.. take it off and see if it has a size listed on it. like 1/2" or 3/4"
you can get them at autozone, its not a preformed hose.. i think there is only 3 preformed hoses on TPI cars..
Old Jul 12, 2002 | 04:45 PM
Brian'sIROC's Avatar
This would be a good time for you to do a throttle body coolant bypass mod. This mod will eliminate that hose your looking for. Check out the tech articles.
Old Jul 13, 2002 | 01:45 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Unfortunatly, the base to TB hose on a TPI is preformed and highly unlikely available at autozone (maybe special order tho). I got mine at the dealer for a few $. Other option (maybe the better of the 2) is mentioned above by Brian.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
