What are our radiators made of?
Old Jul 13, 2002 | 08:54 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Are our radiators copper-brass or aluminum? I read somewhere that GM made aluminum radiators for its performance vehicles but that doesn't sound right.
Old Jul 13, 2002 | 11:59 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Well all radiators are made of some aluminum. The cooling fins are always aluminum.
The tubing is another story. I've never seen brass tubing, but I guess some company has probably done it. Normally copper is the metal used for the tubing. Then the casing is normally steel. It's the best for strength and definetly the cheapest metal.
If you want to spend the money on an aftermarket radiator (ex. BeCool) then you will get a 100% aluminum radiator. Everything on theirs are aluminum. And they cost (IIRC) about $550-$600 for our cars. That would keep my car cool, but keep my wife HOT for spending that much on a radiator. But if you drop ~$10K for an engine, that's cheap insurance. (Not that she'd let me spend that much on a engine either )
AJ
Old Jul 14, 2002 | 12:54 AM
trans87's Avatar
Ok thanks man. I don't plan on a new radiator anytime soon unless my car all of a sudden decides it wants one
Old Jul 14, 2002 | 08:19 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The stock GM is a combination aluminum/plastic unit. The OE unit made by the Harrison division of GM is actually a very high quality radiator. They will last in most cases an excess of ten years. Many people complain about the plastic tank, however if you remember to not add coolant or water when it is hot they are in fact reliable. I totally agree that there are very high priced units out there, but unless you race or expect extreme conditions to be placed on the cooling system there is little cost vs. benefit to a $600 unit.
Old Jul 14, 2002 | 12:07 PM
iroc22's Avatar
The Vette's in the 60s had aluminum radiators. Not sure if they continued that into the 70's.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
