Oil Cooler
Old Jul 18, 2002 | 12:12 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
Oil Cooler
Has anyone installed an aftermarket oil cooler on there 305 or 350 tpi. if so I was just thinkin of doin it I was wondering what this would do for my engine. would it give me power? would it make it run cooler? would it add life to my oil??
Old Jul 21, 2002 | 01:39 AM
iroc_cragg's Avatar
I am planning on getting an oil cooler for the 305 tpi. I have heard a couple of things an read a couple of things. The oil cooler will keep the oil cooler protecting it from thermo brackdown. The oil will last longer and it will keep the engine a bit cooler seeing how cooler oil is running through the engine.
Thats all that I know about them but I would like more information on them also
Old Jul 21, 2002 | 11:48 AM
nitrobreth's Avatar
a couple of more questions on oil coolers,
1. are there different types?
2. what type works best?
3. how do they install?
Old Jul 21, 2002 | 12:17 PM
iroc_cragg's Avatar
There are lots of different brands out there, have a look at jegs or summit to see what kinds they have. They install easy I would think. All it is, is a little radiator that the oil goes through that cools off. It takes the oil from the oil pan to cool it.
Old Jul 21, 2002 | 01:07 PM
nitrobreth's Avatar
i would've thought that they somehow took it from the filter, and PUMPED it through the cooler, that way, all of the oil that circulated would be cool. guess i was wrong
Old Jul 21, 2002 | 01:09 PM
iroc_cragg's Avatar
I dont know if I am right. I read that the oil is taken from the oil pan then passed through the cooler and then to the filter and used and then the process starts over again.
But I could be wrong...
Old Jul 21, 2002 | 10:04 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Alright guys heres how it works there is a little thing with two hoses that attaches where your oil filter should go then your oil filter piggy backs on top of that and each hose runs to the oppisite sides of the cooler. the cooler uses your stock oil pump to pump the oil through the cooler thus making it a fairly easy mod.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
