AC blows cool but blows weak
Old Jul 26, 2002 | 09:03 PM
tomdautel's Avatar
My AC blows nice and cold but even after replacing the blower fan the air comes out very weak. I/ve made sure that each step of the four position switch changes how much the air comes out but even on max AC and the switch on hi the air comes out weak!!!
Any suggestions???
Old Jul 27, 2002 | 03:14 AM
WestCoastChevyLover's Avatar
Check your air ducts!
Im no expert, but I would suggest checking your airduct system behind the dash of the car. If you have ever done a heater core (as i have) you begin to see that the air from the blower motor is routed to the vent through a series of plastic ducts, held together with screws. Something could have rattled loose or you could simply have a crack in it from heat/wear. This could result in your air going elsewere.
Good luck
Old Jul 27, 2002 | 09:34 PM
breathment's Avatar
did u clean the trash from off the evaporator? ud be supprised how much crap can build up on there.. also 3rd gens are known for having crapy blowers..
Old Aug 2, 2002 | 04:50 PM
dale davidson's Avatar
wheres the evaporator located?
Old Aug 4, 2002 | 12:44 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Its in front of the radiator, you might even mistake it for a radiator if you do not know that much about cars.
Old Aug 13, 2002 | 08:13 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
It sounds like he is talking about air flow coming out of the vents rather than the temp of the air, in which case the evaporator wouldnt have any effect on that. I dont get much flow either, but it hasnt been that big of a concern for me yet to look into that problem.
Old Aug 15, 2002 | 08:56 AM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
The Evaporator is in the dash/firewall. The Condenser is the A/C part that is in front of the radiator
Old Aug 18, 2002 | 09:45 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The high blower motor speed power comes from the blower motor relay in most cases. Previous lower settings go through a resistor, but when you go to full out the relay kicks in. Relay is usually located in front of the blower box sitting by itself.
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
