Jet fan switch install - what the hell!
Old Jul 31, 2002 | 06:37 AM
The Josh's Avatar
Ok, last weekend I jacked up the car to install my Jet low temp fan switch. The instructions say I need a 13/16 long slot socket to install it. WRONG!
First, neither old nor new switch was 13/16. They both were 7/8.
Next, the long slot socket would not fit between the switch and the inner fender AND let me attach my driver, even with a u-joint! And, the regular socket would not clear the metal tang coming out of the old one!!!
Am I missing something? Do I need to take the motor off the mounts to get at this thing? What did I miss with this damn thing? Thanks.
The Josh...
Old Jul 31, 2002 | 08:16 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Can you get a combination wrench on it? I removed my fan switch and put in a plug, from the top, with a deep socket and a regular one.
Old Jul 31, 2002 | 10:10 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I used a regular short socket with a 3/8 drive breaker bar. Also, I had to remove the upper dip stick mounting bolt and pull the dip stick tube out a little.
Old Jul 31, 2002 | 11:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I cut a 7/8 open end in half and used that. Took 10 minutes.
Old Aug 2, 2002 | 11:32 AM
The Josh's Avatar
I will tell you all this: the 180 thermostat helped wonders! Big difference in how she runs...
I am gonna hve the oil changed by a shop this weekend. I might see if they can change the switch for me...
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
fasteddi
Sep 2, 2015 10:29 AM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
