dual fans question
Old Aug 8, 2002 | 09:10 PM
rogz's Avatar
Car: 84 Trans Am HO
dual fans question
I am going to swap out the single fan in my 84 TA and put in the dual fans that came with the newer models. My question is, is there any problem(s) if i just wire both fans to the original single wire so that they both come on at the same time? Can i just splice the original single wire to power both fans?
Old Aug 9, 2002 | 06:56 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You will need two fan relays. One relay will NOT handle the current both fans draw. You can turn on two relays with the temp switch, that should not be a problem, but you do need the extra relay and related wiring.
Old Aug 10, 2002 | 09:44 PM
dhjr's Avatar
I am also getting ready to upgrade my car to the dual fans. Will I need two relays if I want to hook one fan up to the existing relay for my single fan and then run the second fan off of a switch in the inside of the car?
Old Aug 11, 2002 | 05:28 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is the best way to do it. Problem is that most garden variety toggle switches cannot handle the current the fan motor draws. The fan motor can draw in excess of 20 amps on initial start up and normally anywhere from 6-10 amps continuous when running. Even if you get a switch heavy enough you will still need pretty hefty wire to and from the switch. By using the relay you can keep the wiring to a minimum for the high current to the fan motor and run only a single thin wire to the switch in the car. The other terminal of the switch will just go to ground.
Old Aug 11, 2002 | 09:23 AM
rogz's Avatar
Car: 84 Trans Am HO
can i just hook up one fan to the original wire and then put the second fan on a manual switch which i can control? I'm just looking for the easiest route for now and may upgrade to the system in the tutorials section later. If i can run one fan manually, how is it basically wired?
Old Aug 11, 2002 | 03:09 PM
breathment's Avatar
here, look at where the manual switches are installed
Old Aug 11, 2002 | 10:48 PM
dsavio's Avatar
thanks for the great wiring diagram i am going to dual fans tool.
Do you know if the 2000 camaro dual fans will hook up in our cars.
thanks again
Dave
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
