With Rad Cap Off Coolant Shoot Outs!?
Old Aug 23, 2002 | 10:11 PM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
With Rad Cap Off Coolant Shoots Out!?
My coolant disappears in freeway driving. Never at an idle.
Sometimes i can go 20 miles before its gone, sometimes 2. No rhyme or reason to it.
I also noticed that with my radiator cap off, coolant comes shooting out of the radiator.
Someone tell me wtf is going on. ;-)
I have my heater hose disconnected, and a hose that goes straight from the intake to the top port on the radiator.
I thought it was the radiator, so i had to flow tested etc and it's fine.
Old Aug 24, 2002 | 12:49 PM
WaynesRS's Avatar
Uh , it shoots out on any car when the motor is hot and you take it off . What do you mean it disapears ?
Old Aug 24, 2002 | 07:12 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
shoots out, is there a pattern to it and with the radiator cap on and full when you drive down the road, and it disappears but you can't find an external leak, it may be going internal, mean a cracked head or something, PULL your dip stick and see if the oil level is higher then normal, if it is it tells you water is leaking into the crank case.
Old Aug 24, 2002 | 08:02 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
Maybe it was a cracked head, i am replacing the entire engine with a 500hp 383 stroker... just hoping i dont have the same probs.
And to the guy who posted first.. I could have the engine totally cold, take the radiator cap off, and start it. Coolant would start overflowing immediately.
I might want a higher flow water pump with the new engine anyway..plus mine looks all rusted
Old Aug 24, 2002 | 08:14 PM
well what I would do is fill up the radiator, cap it and don't open it again. NOW just watch and add fluid to the catch tank, if after about 10 heat ups and cool downs your still adding water and you can't find an external leak then it's going internal. If your losing it faster then that well? Check the dip stick and also check really had for external leaks, check weap hole on transmission clutch cover , this will show you if the freeze plugs in the back are leaking or not.
Old Aug 24, 2002 | 09:31 PM
mechanicalmehem's Avatar
if it is bubbling a lot and never seems to settle down when it is running then you have atleast a blown head gskt maybe head/block the longer you drive it like this the worse it will get it is being burnt in the combustion chamber,
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
