bad belts and cooling
Old Aug 23, 2002 | 11:47 PM
86IROC350NY's Avatar
can this cause overheating. this is my problem:
I get to the highway and I will get the car to 230, then I coast and the temp goes up a few degrees and starts to go down. then when I put it in gear and step on the gas the temp goes down again to about 190...then bact to 220 in a few min of 70 MPH driving. I know I have bad belts. So can slipping cause the water pump to not flow as well?
--Dan
Old Aug 24, 2002 | 07:28 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Sounds like your termostat is shot, replace it. Well if your belts are old just get new ones.
Old Aug 25, 2002 | 09:38 PM
iroc22's Avatar
It's a possibility though I wouldnt rule that out as a solution. Replace the belts anyway and see what happens.
Old Aug 26, 2002 | 04:18 PM
breathment's Avatar
i agree that it might be the thermostat .. also double check ur air dam.. it might even be the water pump.. but start simple first
Hotrodboba400
Dec 10, 2019 07:07 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
