Wiring fan to come on w/ign
Old Sep 17, 2002 | 06:23 PM
ThirdGen Stoner's Avatar
Can someone please tell me how to wire my elec fan (88 305TBI) to come on as soon as I turn on the ignition? It would be much appreciated!!!!!:hail:
Old Sep 17, 2002 | 07:58 PM
breathment's Avatar
find ur fan relay. there should be a small green\w going into it. cut that and attach it to ground. thats it.. but the only control u have over it is from the ignition itself. i recomend a switch..
here is a diagram, urs is the same except it has only one fan..
Attached Thumbnails Wiring fan to come on w/ign-fandiag.jpg
Old Sep 18, 2002 | 07:45 PM
Thats the only contol that I need. I want it to come on and stay on when im driving.
What should I use for a good ground?
Old Sep 18, 2002 | 09:34 PM
rezinn's Avatar
The body. Just make sure there isn't any paint there or it won't make good contact.
Old Sep 20, 2002 | 04:56 PM
Old Sep 20, 2002 | 05:55 PM
turtle's Avatar
i pulled the pig tail off the sensor took a junk sensor and cut off the connector so i didnt have to butcher my new pig tail and used it to run a lead to a switch but if you ran it to ground it will come on as soon as the ignition is on. in my case i have it wired so both fans come on at once but even if i leave it off 1 fan comes on but only at about 240.
Old Sep 21, 2002 | 11:18 AM
Well I fixed it last night. I took the green wire w/white stripe and cut it and grounded it to the bracket that holds all the relays on the firewall and it works fine. Thanks guys.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
