Low temp fan switch for cheap!
Old Sep 30, 2002 | 07:39 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Hey, I found this site online that sells low temp fan switches for corvettes. They work on f bodys also though, so I ordered one and installed it today. Its half the price of hypertech's switch, and turns the fan on at a significantly cooler temp than the stock switch or even the one that everyone is using of an 87 Buick Regal 4.6 turbo. I believe that one comes on at 220. This one comes on at 200, and I like it much better. Heres the website:
click here
Old Sep 30, 2002 | 09:22 PM
90FirebirdV6's Avatar
will this work on the 3.1 v6 also?
Old Sep 30, 2002 | 09:31 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I just had my primary fan activation temperature changed when I had my chip done. Now I just need to do the manual fan switch for my secondary fan.
Old Sep 30, 2002 | 10:06 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
I don't know if it will work on the 3.1. When I said it would work on Fbodies, I was thinking v8 wise, sorry about that. Go to your local parts store and see if the v6 fan switch and one for a v8 are similar. If they are, then it will work.
Old Oct 3, 2002 | 11:26 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
yea it will work. those L4 fierro switches work in v8's so why wouldnt a V8 switch work in a v6. Im 99.9% sure it will. anyways its only $20
Old Dec 5, 2002 | 05:52 PM
68Beater's Avatar
18.95 switch...
Did you have to buy the harness for that switch to work?
Old Dec 5, 2002 | 06:00 PM
68Beater's Avatar
And do you have the dual fan set-up or the single fan set-up? Does the single fan set-up require the wiring harness?
Old Dec 5, 2002 | 06:17 PM
maddog's Avatar
Put one on my 91 with a single fan, did not need the new wire harness, works great
Old Dec 6, 2002 | 11:46 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
I only have one question. The switch only turns on the secondary fan, right? So if you buy and install that harness aswell for TPI cars that have duel fans will it turn both of them on at the stated temp?? or is that only possible by burning a new prom??
Old Dec 8, 2002 | 02:51 PM
MdFormula350's Avatar
looks good, too bad i already put a factory one back in. but i do have a switch for the same fan so i can turn it on and off when needed.
eightsixseven
Dec 16, 2024 01:50 PM
italiano67
Dec 11, 2016 09:21 AM
soarestransam
Sep 1, 2015 04:00 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
