Vacumm hose for AC vents?
Old Oct 20, 2002 | 04:14 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Can anyone show me a picture or give me a good description of which hose is supposed to make the AC vents work on a 91 TBI motor?
Old Oct 20, 2002 | 05:35 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i believe that it is a hard black plastic line that comes out of the firewall above the heater core hoses and towards the passenger side a little bit
Old Oct 23, 2002 | 05:49 AM
Andy Bush's Avatar
I think the heater and A/C controls are supplied via the vacuum reservior which is the plastic cylinder located on the fire wall near to the MAP sensor.
It has non return valves to stop it affecting the MAP sensor. They need to be checked and working OK.
The vacuum connection to the reservoir can come from any spare connection into the throttle body or directly from the manifold cover. Its hard to see where the original supply came from, but it will work from any of the connections.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
shanelique22
Sep 24, 2015 06:30 PM
