pro's & con's
Old Oct 21, 2002 | 03:22 PM
confucius101's Avatar
pro's & con's
ok i have a 91 3.1l firebird w/ac
what would be the pro's & con's of adding a
tranny and or oil cooler????
Old Oct 21, 2002 | 10:03 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
improved life - get both if you can
Old Oct 26, 2002 | 01:48 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It's a matter of opinion. Many experts claim different things. Racing or towing or severe street use trans cooler is probably worthwhile. Normal use, go with a synthetic trans fluid. Ditto for engine oil. Use synthetic and forget the cooler. GM changed the vette factory fill to syn to eliminate an oil cooler. I dont like aux coolers because it's just another place for leaks to develop and with modern syn technology it's a waste of money and adds weight.
Old Oct 31, 2002 | 10:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd definately get the trans cooler, as it will greatly increase the life of the tranny.
Old Oct 31, 2002 | 07:28 PM
z28_dave's Avatar
From: tokyo - where the girls are pretty and the cars are fast
there are additives you can use to reduce tranny temps
Old Oct 31, 2002 | 09:23 PM
82camaro's Avatar
Car: 82 camaro SC
IMO, additional tranny cooler is always worth it. Engine oil cooler in extreme conditions.
Old Nov 10, 2002 | 08:03 AM
StangKiller's Avatar
Trans cooler is always a good idea, just make sure you keep the factory cooler hooked up that's in the radiator, run the add on cooler after the factory cooler. I don't think an engine oil cooler is necessary in your case, but it won't hurt.
Old Nov 10, 2002 | 10:04 PM
MdFormula350's Avatar
pros = helps keep things lasting longer...
cons = cost money, a place for leaks to occur, and takes up some space...
F.I. 57 Belair
Aug 23, 2021 01:09 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
3.8TransAM
Sep 17, 2015 02:16 PM
scotrans am
Sep 5, 2015 04:26 AM
