Where is my fan switch suppose to be?
Old Oct 22, 2002 | 12:10 PM
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
I have an 84 z28, which I recently installed a 350 into (replaced the
lg4). When I installed the 350 I upgraded my cooling system, and
went to an electric fan. I installed the fan switch in the intake
manifold, which I thought was the stock position on these cars
(I included a picture). However, I have been reading posts about
fan switches on this board and keep seeing that they are installed
between the #6 & 8 cylinders. Now my question is if this location
is for post 86 cars and if I have the switch in the right location?
I was also wondering if Jet makes a switch for my car, because
the NAPA stock replacement doesn't turn the fan on until ~235 degrees.
Also, I have a performer intake manifold, and could the switch
be turning on so late because the manifold is dissipating the heat
quickly (coolant in the manifold location is cooler than in the engine).
Old Oct 22, 2002 | 03:39 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
put it in the passengers side head. it might not be hurting anything there but if you are worried....
Old Oct 22, 2002 | 08:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
On a stock (I know you said that's not the original motor) '84 LG4, the location you pictured(circled) is for the ECM coolant temp sensor.
IIRC, Vader drillerd and tapped his thermo housing an put a fan switch there on his motor though.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
