dual fan wiring
Old Oct 30, 2002 | 06:45 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
dual fan wiring
here is how i am gonna wire up the dual fans. i had a single fan originally and i have my fuel pump relay that i am not using so that is the relays i am using. for the connectors that go into the fan i am going to use stander 1/4" female connectors. once again i am using tranny cooler ties with washers. how far should i get the fan mounting tabs from my radiator?
here is the fan switch i want to use with a 180* stat
http://www.jegs.com//cgi-bin/ncommer...74&prmenbr=361
Old Oct 30, 2002 | 07:35 PM
MdFormula350's Avatar
looks good, so basically you cut out the ecm side of it, and are are taking the f wires on each relay and hooking it up to the fan switch, so when the fan switch detects the 200 temp it will ground both relays and turn on the fans..
the only thing i can think of that you might need to do is for safety reasons install a manual switch just incase the fan switch malfunctions you can turn on the fans without overheating.....
Old Oct 30, 2002 | 08:24 PM
yeah i might do that. thanks
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
