Cooling passages in the heads?
Old Nov 1, 2002 | 08:09 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
How can I find the cooling passages in the heads? How do I know which ones are the cooling passages. Some of the cooling passages have bolts going through them. This is a 455cu in Buick motor that's going in my third gen.
Old Nov 1, 2002 | 04:18 PM
rezinn's Avatar
I've never seen the inside of that engine, but you can just look into the ports and the ones that you can't see the tops of valves in will be coolant passages. It'll also be fairly obvious if the engine has some miles on it, since only air flows through the ports(and gas).. and the coolant passages will most likely be dirty and still have traces of coolant in them. Most likely one on the front and one in the rear of each head.
Old Nov 4, 2002 | 09:53 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
455 Buick! i used to be into buicks, torque monsters.they did a spread in carcraft afew years back when a guy put one ina transam. don't remember the particulars but don't they have main bearing problems? don't you have to reroute the oil to the mains. i may be wrong but my conscience makes me bring it up. oh and save your money for parts
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
